Go to Post first robotics is a ten - Hiteak [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 03-04-2003, 17:41
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
Championship layout
Anyone know what the layout of the venue will be? Will all fields be in the same area, or will they be spread out around the park? Will Einstein still be the main stage with a huge setup?
Unread 03-04-2003, 18:16
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Well... there is no Einstein this year, so I'm assuming that the main field will either be called another division, or the "Main Field".
I'd also be sure that they rotate teams thougth it. Also, does anyone know... (not to be dumb)... but, are all the fields going to be covered??
Thanks,
Jack
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 03-04-2003, 18:17
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
I totally forgot! NO EINSTEIN!!! I HATE YOU HOUSTON!!!
Unread 03-04-2003, 18:23
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, I heard there might be a fifth field. If so, it would probably be Einstein.
Jeff Waegelin
Unread 03-04-2003, 18:37
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Ya I thought I had heard someting like that too. You can get rid of Einstein. I think it'll be the main stage just for finals, but I could be wrong.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 03-04-2003, 19:17
118 Tech's Avatar
118 Tech 118 Tech is offline
TECHsan
AKA: Chris David
FRC #1817 (Llano Estacado RoboRaiders)
118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light118 Tech is a glorious beacon of light
From what i read on the FIRST site they mentioned 2 venues, Reliant Stadium and the AstroDome.
What i was figuring was that the floor of the Dome would be the main pit area. There are access ramps with huge garage like doors leading from the street level to the floor of the Dome. These would be used to get robots to and from the pit area.
For the actual layout of the playing fields i was thinking they may place them on the floor of Reliant Stadium and maybe a video board behind them. Maybe something like the different configurations in the picture i attached. The stands would be normal stands of the stadium. For a main stage just build a stage at the center or something. All this may make scouting easier because all of the stadiums are in one place.
For the main court yard where you could put things like picnic tables, the big FIRST banners, and practice fields, you could use the area between the stadiums.
If you are wondering if these venues are covered the anwser is Yes and No, The Dome is covered. Relaint Stadium has a retractable roof, so if you want it covered then it is, if you dont then it doesnt. Also both venues are airconditioned. For Reliant Stadium if the roof has to be closed.
I'm excited to see how things are going to run in this new venue in my hometown, besides other reasons. From a Houstonian, (actually a League Citizen and now a TECHsan in Lubbock), to the FIRST community, WELCOME TO HOUSTON!!!
Chris David
Software Engineer
SnapStream Media
118 Robonauts
2000-2001
"Once a Robonaut always a Robonaut"
1817 Llano Estacado RoboRaiders
2006-2007
Couchville - Simple TV Listings
Unread 03-04-2003, 19:51
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
For real efficiency you would have four fields, two in each stadium, each division would have a dedicated field. Then behind those fields would be the pits for each division. Frankly I hope that we aren't going to be running back and forth between two STADIUMS. Frankly, I think it would be easier for one division, one field.....No silly running around to different fields being re-routed all over the place according to what time it is.
Just my dos centavos
Unread 03-04-2003, 20:07
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
One division, one field is also much better for...
....scouting.
Let's hope this is the case.
Scott358
Unread 03-04-2003, 20:13
Matt Reiland's Avatar
'The' drive behind the drive
I was talking to chief delphi today at Western, they hinted at the distance from field to pits being almost a half mile walking. Plan on innovative methods to charge your batteries (maybe even in route) especially for the finals!
Unread 03-04-2003, 20:21
118 Tech's Avatar
TECHsan
AKA: Chris David
Actually that sounds like a good idea, 2 pits one in each venue with there fields right there.
I think if they do have the pits in one place and the playing fields in the other, it wouldnt be that far to walk. Here is a map. Walking from the two may be even shorter than walking from the far end of the pits, to Eienstien at Epcot. The pits then were long by themselves. You could fit 4 Boeng 727's nose to nose in that space thats the pits alone.
Anyways hopefully it wont be bad.
BTW i dont think that they would rotate fields in either configuration. I thought the reason to rotate is to get every team a turn on the big field. If all the fields are the same, there would be no reason to.
Chris David
Software Engineer
SnapStream Media
118 Robonauts
2000-2001
2006-2007
Unread 03-04-2003, 21:01
Joe Matt's Avatar
I can sware that Reliant if for the fields and Astro is for the pits, but you never know...
Unread 03-04-2003, 21:34
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
That's what they said, the Astrodome would be the pits and all of the fields were going to be in Reliaint Stadium. The half mile walk being the distance between the Astrodome and Reliant Stadium.
Unread 03-04-2003, 21:41
BSEE, MSEE, JD
AKA: employed
half mile walk each way? that is ridiculous....if that is the case it shall once again be a poorly planned event (OMG*UCF*OMG). I guess I can't be too upset as long as we aren't out in tents. If it is a half mile walk....I cannot wait to go back to Epcot.
Unread 03-04-2003, 21:46
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Duh, we're all getting golf carts to pull our robots
Ricky Quinones
Director of Sales - VEX Robotics
Unread 03-04-2003, 21:55
El Jefe de 148
Or Segways, perhaps?
Jeff Waegelin
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - Constructive Criticism Andy Baker Championship Event 7 29-10-2003 16:48
QotW 6-01-03: The Championship Madison Rumor Mill 13 02-06-2003 06:06
Championship Registration Filled Travis Hoffman Championship Event 0 01-04-2003 21:20
Date for Championship? Bob92 Championship Event 2 18-03-2002 16:16
