Go to Post Sometimes the complex can be done very simply. - Cory [more]
Unread 21-01-2002, 19:38
mpatterson mpatterson is offline
#0610 (Crescent Robotics)
mpatterson is an unknown quantity at this point
BASIC Stamp Error
I am trying to download a program into the robot controller but I keep getting the following error:
"No BASIC Stamps Found."
I have checked all the cables and followed the instructions but I always get this error. Any help would be appreciated.
Mark
Unread 21-01-2002, 20:36
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
Check the following things:
-Robot is turned on
-Programming cable connected securely to both computer + robot
-no programs running on the comp that use the COM port such as palm hotsync.
-The correct COM port is selected in the basic stamp programming utility on the computer
Thats all i can think of for now... try these, if it still doesnt work after i'm sure someone else can point you in the right direction.
Tom
Unread 21-01-2002, 21:04
s_alaniz s_alaniz is offline
#0057 (Leopards)
s_alaniz is an unknown quantity at this point
windows?
If you're using windows, make sure you have the STAMPW program for windows and not just the DOS version (which runs but will not communicate).
Best Wishes
Steve Alaniz
"You're saying we can look forward to robots behaving badly and demanding higher salaries." - Sally Forth
Unread 21-01-2002, 21:45
Matt Reiland's Avatar
'The' drive behind the drive
Unhappy Same thing
On my laptop the new version of the stamp editor does the same thing, make sure you have selected to use the right COM port. As soon as I load the program with the older version of the editor 1.096 or something like that works fine. Took it to another laptop and it downloaded just fine with the new software and the old? BTW I am using Win2000 the other laptop is Win98. Hope this helps and if you need the old version I can probably send it to you
Good Luck
Matt
Unread 22-01-2002, 12:08
Problem Fixed
Downloading BASIC Stamp Editor v1.1 from the parallax website fixed the problem. Thanks for the help
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
Basic Run Error BBFIRSTCHICK Programming 10 02-04-2003 22:43
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
no basic stamp found! DLyons Programming 7 23-12-2002 22:17
BASIC error punarhero Programming 4 16-02-2002 23:21
