Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
Unread 22-01-2002, 17:40
joni_m joni_m is offline
joni_m is an unknown quantity at this point
replacement gears
Does anyone know where replacement mating gears for the chiaphua motor can be bought? Where can we buy gears with a 25 degree pressure angle and a diametral pitch of 36?? Thanks for your help!
Unread 22-01-2002, 18:01
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
you can buy the motor assembly including motor, cluster gear and other stuff for 237 directly from atwood. I also think a full jack costs 247 or something like that.
As far as just the gears, you might have some trouble, they are far from standard.
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
