Go to Post Like a wizard, Car Nack is never late. He always arrives precisely when he meets you. - EricH [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 13-04-2003, 15:19
jon virgi jon virgi is offline
#1191 (Eagles)
jon virgi is an unknown quantity at this point
Send a message via AIM to jon virgi
why did technokats have lots of problems?
Anyone know why the technokats had so much trouble this year with their transmissions or whatever was preventing them from moving to well, so often?
Keystone Oaks Robotics Team President / Webmaster / Lead Pneumatics designer / Lead electrical........
Unread 13-04-2003, 19:16
D.J. Fluck
Posts: n/a
Heh quite an amusing story,
We were running great until one match the victor attached to our left side drill motor blew because metal shavings from the gearbox shot up into it and yeah, it stopped working. We replace it and go to our next match were the same darn thing happened on the right side to the drill motor BAH!
Saturday we had no problems until we got to the finals and we had a major collision during auton mode and we never had full voltage for the rest of the match. Afterwards we pulled the bot off to the side and checked it out and from that collision the nut on the fuse pannel for the main breaker ground wire came loose and the crimp basically never was fully connected...doh! It wasnt my fault, but it was my responsibility so I am fully taking the blame for it. Oh well.
Unread 13-04-2003, 19:50
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
here's another technocat-related albeit slightly off-topic question:
why did the technocats switch from a six-motor drive assembly (drills/chips/fisher-price) last year, to a four-motor drive assembly this year?
What it basically boils down to is that my team is looking into a six-motor drive four next year, and I'm trying to do some homework as to wether or not it is feasible/useful, or simply overkill.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 13-04-2003, 19:56
D.J. Fluck
Posts: n/a
Why you ask?
heh its because we pulled way too much current last year and frequently tripped our 60 amp breaker. Plus this year we used 9 motors and we needed the two FP's for our arms
Im not trying to discourage you from doing it...more power to you
Unread 13-04-2003, 20:38
Austin's Avatar
Austin Austin is offline
Go TechnoKats!
FRC #0045 (TechnoKats Robotics Team)
Austin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to allAustin is a name known to all
Send a message via AIM to Austin
Originally posted by D.J. Fluck
Why you ask?
Also, it was because it was simply overkill and we didn't need it....actually we took off two of the motors last year too b/c of the overkill and breaker trippage thing, so we only had a 6 mtr drive base for a short while.
Austin Butler| Mac Addict | Purdue AAE | President, Sigma Gamma Tau | ENS USN/Student Naval Aviator
2002-2005 driver | 2004 Lead Mechanical | 2004-2005 Co-Student Leader | TechnoKats Robotics Team 45
Need a gearbox? Omniwheels? Check out AndyMark.biz
Unread 13-04-2003, 20:56
Solace's Avatar
AKA: Jake
so, from what I'm hearing, the general consensus is that its not a good idea?
...What is a man,
Jake
Team Paragon #571
Unread 13-04-2003, 21:02
D.J. Fluck
Posts: n/a
No, not necessarily....
Jake, use your resources wisely....dont sacrifice a motor to your drivetrain if you could find other usage for them that would be better....the way we did it was overkill, but heck who knows what you guys could design
Unread 13-04-2003, 21:10
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is online now
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
another reason i could think of...
This years drill motors are alot more powerful than last and that will help make up for the power loss associated when dropping out the 2 FP motors.
I think the 4 motors they used this year were probably just as powerful as the 6 motors they used last year.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 13-04-2003, 21:21
jburstein jburstein is offline
jburstein is an unknown quantity at this point
what i want to know is how much advantage do you get by adding motors beyond 2 per side (if you're doing tank drive)? It seems to me that no matter how carefully you calculate your gearing there'll still be some variance in the actual motors (especially after a few rounds of competition) so won't they either wind up fighting each other, or one motor wind up pulling all the others behind it?
Unread 13-04-2003, 21:35
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Ready for 3
The gearbox this year was actually ready for the addition of the Fisher Price motor as you can see in the picture. We decided against it because we needed the motors for the wings.
http://www.pictars.com/0412003/03-45-gearbox.JPG
(copy & paste link)
Purdue Alumni
Cummins, Inc.
Unread 13-04-2003, 21:36
Solace's Avatar
AKA: Jake
do you think that your three motor design would have continued to trip stuff even with the new 120a breaker?
...What is a man,
Jake
Team Paragon #571
Unread 13-04-2003, 22:30
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Before you do that i would work out the power you could achieve with just the CIM and the Drill's. Those 4 can pull 160 amps which theoretically is enough to trip the breaker(it really won't). Secondly you need to find really high traction wheels if you really want to use that power. i think the technokats tore up the carpet once with that 6 motor system at nats(they had those metal treads). It might have been a different team, but either way they had more power than they could use.
If you're working on it now. You have time to really calculate it all. Thats what i'm doing. But i'm going for something slightly different. My plan
Team Website
Unread 13-04-2003, 22:43
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
With 130 lbs. It would be hard to transfer the power to the wheels anyway. It would be overkill.
Unread 13-04-2003, 23:25
D.J. Fluck
Posts: n/a
Heck we ripped carpet all the time...but anyway at certain points during matches last year we pulled over 200 amps with the old drill motors, cims and FP motors....and that was on a 60amp breaker...
basically right now with the motors and assemblies we have delt with, 6 has been overkill...keep working on it though, maybe FIRST will give out new motors next year (this isnt a confirmed fact nor a rumor.)
Unread 14-04-2003, 00:21
Ianworld's Avatar
AKA Ian Ferguson
AKA: Ian Ferguson
i hope they don't put out new motors. I find it pretty annoying. We have to design new mounts and interfaces for them. Instead of improving old ones.
Just as a note though, that 60 amp breaker could do up to and sometimes over 200 amps for some period of time. It could consistantly do 120 amps easily(the matches are only 2 minutes). Thats why i was slightly worried that the new breaker would actually be tougher to use because it would be more accurate. Turns out its just good/bad. My team probably pulled about 160 consistantly this year and our breaker never tripped(our robot did... but thats different).
Team Website
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
TechnoKats' designs - responses needed Andy Baker Chairman's Award 0 29-01-2003 09:52
Joystick problems archiver 2001 3 24-06-2002 02:40
Thanks Andy Baker and the Technokats!! archiver 2001 2 24-06-2002 01:04
Thank You TechnoKats Dana Hobbs Thanks and/or Congrats 1 06-01-2002 23:37
