Go to Post Autonomous Mode (n): A moment of silence observed prior to every Week 1 or Week 2 match. - Dan Petrovic [more]
Unread 23-01-2002, 07:08
Originally posted by Anton Abaya
how do you calculate the traction of your wheels/treads/drive train traction into in-lbs?
i'm curious to figure ours out.
Using the friction-pull test above, you know the force; Force (in lbs from a spring scale) times radius of the drive wheels (in inches) will produce the torque at the wheel hub. All the rest is gear / sprocket tooth ratio.
traction questions AlbertW Rules/Strategy 2 05-01-2003 17:58
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
How fast could a torque motor turn if a torque motor could.. archiver 2001 0 23-06-2002 22:54
Gear Woes Simon G Technical Discussion 14 24-01-2002 16:31
