Go to Post I am allergic to work... - Mike Schroeder [more]
Unread 23-01-2002, 16:35
jeffreym jeffreym is offline
#0802 (The Lost Bearings)
jeffreym is on a distinguished road
To measure current from the battery (or to the motors for that matter), you should put a very low resistance shunt in series with the power lead. Technically it doesn't matter which one but we use the positive lead. You then have a low voltage (in the millivolt range) that can be measured across the shunt and amplified (with a simple op-amp circuit) to accomodate the 0-5v of the A/D converter on the controller. We (Team 802) are measuring total battery current and that's how we are doing it.
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
Robot Controller Digital Input crazycliffy Electrical 11 16-02-2003 04:28
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
