Go to Post Do you think Pizton's Lard would want to be a FIRST supplier and give every team some lard in the KoP? We could grease our gearboxes with it and every finals match could smell like bacon. - Ty Tremblay [more]
Unread 24-01-2002, 02:37
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Re: series vs parallel
Originally posted by nwagers
Correct me if I'm wrong. It's been a while since I've had electronics. I do believe that if you hook an amp meter in series, you will here a loud and distinct pop of a fuse (a breaker if it's a good one). I think you measure amperage in parallel and voltage in series. Don't forget the difference between the two, it's an important one....
Having just had General Electronnics I at the community college, I can say you've got your measurements reversed. Current is measured by breaking the circiut and placing a meter accross the break (series). Voltage can be measured at any point with respect to any other point (parallel).
Like you said, it's important to remember the difference between current and voltage...
CURRENT is a measurement of the number of electrons flowing past a certian point in a given time frame. I've always pictured it as: you break the circiut, forcing all of the electrons to go through the meter, "counting" them.
VOLTAGE on the other hand is a measurement of potential. "Pressure," if you will. When you measure voltage, you've to keep track of what point you are using as refrence. As such, you *could* wire a volt meter in series... but you'd read 0V. The difference in potential accross a perfect conductor is 0. (Try measuring the voltage drop accross a resistor, and then measure the voltage at a point with respect to ground...)
Of course, keep Mr. Ohm in mind! Voltage = Current * Resistance
Hope that helps!
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
Robot Controller Digital Input crazycliffy Electrical 11 16-02-2003 04:28
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
Serious Controller Ideas archiver 1999 28 23-06-2002 23:01
