Go to Post Exercise, eat properly, work hard, live hard, play hard, laugh hard, inspire people, solve problems. And leave the world around you a little better place than you found it. - ebarker [more]
Unread 24-01-2002, 08:12
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Cool Let me take a shot at this
Let's see
I read your post a couple times and I don't think all of the people who responded understand the question. Or maybe I don't.
I think what you are saying is that when you moved the right joystick to full it made the left motor go full forward but ALSO made the right motor move at a lesser level. Thi should not be that hard to code.
Set the left motor value to the value of the right joystick plus the value of the right joystick multiplied by some gain (maybe 1/2). Since you can't use 1/2 you will probably need to get tricky like multiply by 100 amd divide by 200.
Don't forget to add "MIN 254" to the end of the line that you are defining the motor output variable. This will keep the value from wrapping around to 0.
Alot of you guys out there know a lot more about this stuff than e. Did I miss much?
Matt B.
switch speed control wayne 05 Programming 6 01-10-2003 09:35
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
Prgm4 2 joystics control 1 speed cntrl??? punarhero Programming 7 21-02-2002 09:57
