Go to Post An FRC team's success should not be measured in how many robots it can build or how many blue banners it can collect. It should be measured by how many engineers (and other professionals) it 'builds'. - jvriezen [more]
Unread 21-04-2003, 16:00
JAlpert JAlpert is offline
JAlpert will become famous soon enoughJAlpert will become famous soon enough
If you look at all 3 national winners, none of them shifted. Obviously an optimized non-shifting robot is far superior to a shifting robot. Less that can go wrong.
I'm actually somewhat surprised nobody noticed that our robot (469) had a transmission. It ran a drill and a CIM on each side (4 motors total). This is our third year with a transmission, and our second with a custom box.
The reason I'm so surprised is that our transmission had a 7:1 split. We avoided using our high gear much in the finals becuase we bent a driveshaft in our division semis, and at high RPM it threw the chains off the sprockets. We used high gear mainly for the autonomous portion in the finals, and low gear for the rest of the match. The unusually huge split in the transmission was nice, becuase we were pretty fast in high, and powerful in low.
The problem we encountered was that at our first regional, we were snapping shafts (1/4" hardened steel I believe). Once the problem was fixed, the actual transmission gave us no more trouble. However, the cantelievered output shaft was another story . . .
I think our transmissions have been a key part of our robot design for the past few years. Every game has an aspect where speed is necessary, and another where power is needed. Once the kinks are worked out, transmissions can be a very powerful feature.
Jeff Alpert
Team 469
Break Down of Awards By Fields. Josh Hambright Championship Event 13 09-04-2003 10:22
Regional Chairman's Winners starshrike Chairman's Award 23 07-04-2003 12:39
Even more interesting numbers: Division of regional winners archiver 2001 8 24-06-2002 03:10
NYC Colombia Regional Winners MChen Regional Competitions 0 23-03-2002 21:11
Braodcast and web coverage of regional competitions dlavery Regional Competitions 26 16-03-2002 17:21
