Go to Post Border Guard: "Anything to declare?" Team: "Oh, just these trophies!" - dtengineering [more]
Unread 25-01-2002, 17:57
chrisw chrisw is offline
chrisw is an unknown quantity at this point
Send a message via AIM to chrisw
pot help
i'm trying to use a pot to limit a motor to turning only 90 drgrees. I need to know what the value that is stored in the sensor variable represents and how to prevent the motor from turning ( the motor will likely be run through a victor). also, is their a way that i can have the program slow down the motor as it approaches the end of a 90 degree turn?
~ chris ~
Unread 25-01-2002, 21:10
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Brute force...
one way to do it is just to turn your motors off at 90 degrees and to limit them to a lower amount at some lesser amount.
Try the following (as always, off the top of my head, untested but probably not too far from correct)
' assume right joystick movement turns motor right, left turns it left.
' assume steering motor is wired such that PWM1 > 127 moves steering left
' assume pot is wired such that Sensor1 >127 means steering is pointed left
' assume pot is adjusted such that Sensor1 = 127 means straight
'assume you enter the code below with p1_x as your variable that holds the joystick value that you what to use to steer
'assume that the output statement uses p1_x as the output to PWM1
Sensor1FullLeft CON 127 + 100 ' approx value, yours may vary
Sensor1SlowRight CON 127 + 50
Sensor1SlowLeft CON 127 - 50
Sensor1FullRight CON 127 - 100
PWMSlowRight CON 127 - 50 ' adjust to suit
PWMSlowLeft CON 127 + 50 ' adjust to suit
If sensor1 < Sensor1FullRight StopSteerMotor
If sensor1 < Sensor1SlowRight SlowRightSteerMotor
If sensor1 > Sensor1FullLeft StopSteerMotor
If sensor1 > Sensor1SlowRight SlowLeftSteerMotor
Goto DoneSteerMotor
StopSteerMotor:
p1_x = 127
Goto DoneSteerMotor
SlowRightSteerMotor:
p1_x = PWMSlowRight
Goto DoneSteerMotor
SlowLeftSteerMotor:
p1_x = PWMSlowleft
Goto DoneSteerMotor
DoneSteerMotor:
Hope this helps.
If I get a chance, I will post a better way later.
Joe J.
R/C Control types Andy Brockway Programming 43 24-11-2003 17:07
Pwm VanWEric Programming 17 01-11-2002 16:07
100k Slide Pot archiver 2001 4 24-06-2002 02:53
Picker Or Pickee archiver 2000 54 23-06-2002 22:26
More pBasic Woes... Dan 550 Programming 4 11-11-2001 23:08
