Go to Post Only think of Gracious Professionalism as a standard to work toward personally. Never use it as a gauge to point out someone else’s shortcomings. - Rich Kressly [more]
Unread 25-04-2003, 09:01
Matt Reiland's Avatar
'The' drive behind the drive
As for mounting of the motors, the motors are mounted the same as any other gearbox that you would create. The difference is that instead of making the gearbox in a horizontally long configuration with the motors in line flat with the wheels you stand it up on end and mount it vertically so the swing of the steering wheels in the chassis is reduced and the wheels can be mounted closer to the edge of the chassis. See the wildstang pictures for a good look
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
pic: Coaxial Lego Crab drive CD47-Bot Robot Showcase 11 04-11-2003 14:45
rotation of body of crab drive robots michael_obrien Technical Discussion 6 22-10-2003 19:32
EduRobot Crab Drive OneAngryDaisy Robotics Education and Curriculum 8 03-10-2003 10:06
pic: Tytus Crab Drive lego model CD47-Bot Extra Discussion 11 08-09-2003 18:36
