Go to Post Liberal arts majors learning more STEM concepts along with STEM majors learning more 'liberal arts' is a good idea. - ebarker [more]
Unread 28-04-2003, 07:22
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
What teams used wheel encoders this year?
Team 122
How did you build it or did you buy a shaft encoder?
We bought an optical sensor; we built the encoder ourselves from aluminum and attached it to our jack shaft.
What was its resolution?
I think we calculated ours to be +- 3 in.
Did you use them only for autonomous or for the whole match?
Just autonomous mode.
How did they work for you?
They were adequate for our purposes. They did give us some trouble at the beginning, though. One major obstacle we encountered was the resolution of the stamp itself -- about 25 ms if I remember correctly. You might consider using a custom circuit to get better results.
Do you plan to use it next year?
Well, I suppose it depends on the game. But if we do then probably get a custom circuit.
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
3D Model of skyway 20" wheelchair wheel?? Elgin Clock 3D Animation and Competition 2 14-09-2002 16:41
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
wheelchair wheel + F.P. motor ?? archiver 2000 2 23-06-2002 22:44
