Go to Post If you have the time to be caught up on Delphi and the Q&A forum, then you have time to go write a WFA entry. No more excuses. Go! Write! Now! :) - Jessica Boucher [more]
Unread 29-04-2003, 16:43
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Read the Manual (V2.0)
I can tell you that one of the best sources of information I have had is the V2.0 manual.
The intro is very useful -- much improved from prior versions (V1.9 for example).
Also, know that everything to do with direct input and output via Stamp2 pins is more or less useless. You cannot use Pulsin or Freqout for example.
The basic structure of how you make a pin an input or an output is VERY useful (especially if you understand what the commands are doing to the variables INS, OUTS, and DIRS), but all but a handful of the commands that read from or write to pins are out of bounds because you don't have direct access to the pins of the Stamp2 from the RC controller.
Anyway, I recommend reading the book, especially the parts on how expressions are evaluated, how lines are parsed, and how math is performed internally.
Good luck.
Joe J.
Successful Due to Affluence? indieFan Chit-Chat 4 31-05-2003 14:48
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
PBasic Question Melissa H. Programming 28 17-11-2002 18:53
Subtotaling in PBASIC? Ian W. Programming 17 02-02-2002 20:22
