Go to Post How about instead of using the flag we just all wrap out robots in color saran wrap. there! problem sovled! - John Gutmann [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.00 average. Display Modes
Unread 25-01-2002, 20:11
zarb zarb is offline
#0469 (Las Guerrillas)
zarb is an unknown quantity at this point
gear thickness
If gear will be made by a gear manufacturer, is it limited to 1/4 inch thinck steel?
thanx
469
Unread 25-01-2002, 20:37
Sprockets, gears, and pulleys can be any size, as listed in the Additional Hardware List
Unread 25-01-2002, 21:21
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
If you are going to make a CUSTOM gear from legal kit material, then you are often limited to 1/4 inch face widths because 1/4 inch plate is unlimited on the Additional Hardware List.
If you are buying off-the-shelf gears, then you can buy whatever facewidth you can find off-the-shelf.
If you need to make a custom gear AND you want a facewidth greater than 1/4, you can perhaps buy thicker plate stock or even bar stock from Small Parts and use that to have your gears cut.
Joe J.
Unread 25-01-2002, 21:23
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
The way I read it, the any size - any number only applies to off the shelf gears. If you are going to make your own, they must be from materials on the additional hardware list (1/4" steel), or buy the material from Small Parts (I believe they carry steel > 1/4").
Unread 25-01-2002, 21:25
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Question Limit on Gears ?
Joe,
I respectfully disagree.
Gears, Sprockes, and Pulleys are from any source and any amount. Why can't my machine shop be a source of gears just like Pic-Design or any othe gear manufacturer ?
Ed Sparks
MECH TECH FRC-3959
Unread 25-01-2002, 21:32
Jeremy Davis Jeremy Davis is offline
#0422 (Mech Techs)
Jeremy Davis is an unknown quantity at this point
Send a message via AIM to Jeremy Davis
Additional Hardware must be off the shelf
Sorry Ed, but have a look at rule K3.
"Items listed in the Additional Hardware List must be "commercially available," strictly off-the-shelf only. No custom or special orders."
So custom made gears must be made out of materials that fit the specs of other Additional Hardware parts, or material from Small Parts.
Unread 25-01-2002, 21:37
AKA: Dr. Joe
FRC #0088 (TJ2)
Rule K3...
K3.
Items listed in the Additional Hardware List must be "commercially available," strictly off-the-shelf only. No custom or special orders. Items that are normally purchased in a custom size, such as an off-the-shelf belt cut to length for the customer, are not considered custom or special orders.
Am I being too literal here?
Joe J.
Question
Hmmm,
But a 32 pitch 40 thooth 20 degree PA gear IS commercially available. If I make one, so what?
I see it as a splitting hairs thing. Am I really that far off in my thinking?
Maybe, I should have been a lawyer .....
Ed Sparks
MECH TECH FRC-3959
Unread 25-01-2002, 21:55
AKA: Dr. Joe
FRC #0088 (TJ2)
This way lies madness...
If the standard is that I COULD have made this legally from legal kit materials rather that I DID make this legally from legal kit materials, I think we have lost something.
Am I going to loose any sleep over a custom made gear or two? No.
But, I still have to call 'em the way I see 'em.
Joe J.
Unread 26-01-2002, 14:40
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
YOUR BOTH WRONG!
There settled that one, if you ask to me explain why then your even more wrong than before!
MUAHAHAH ok im tired....
Unread 26-01-2002, 22:07
Woodie Flowers Award
Bill Beatty Bill Beatty is offline
#0071 (Team Hammond)
Bill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond reputeBill Beatty has a reputation beyond repute
Wide Face Gears
Five of the last six years we used wide face gears. We used .750 square stock from SPI and hot rolled it and welded it into a ring and then welded it to a .250 thick web plate from SPI. I would hate to think we were being foolish.
Speaking of gears, the FP motor and gearbox IS different this year. We hadn't noticed it until we saw the post. The gear mod we have used in the past will not work, nor does it appear to be necessary. Two more 20,000 RPM motors! I can hear Joe and Andy drooling clear down here in NW Indiana!
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
