#16
I have been reading the innovation first documentation on this, and I have discovered that you can use analog sensor bytes 1 through 5. If you edited these bytes, the edited results would get sent to the oi dashboard port. I want to try this, but I don't have the necessary programming skills yet. Could somebody try this and tell me if it works?
If it does, then you have six bytes in which to put your dashboard data. (I'm still counting the led byte) http://www.innovationfirst.com/FIRST...rd%20_Spec.pdf Oneangrydwarf: I agree with you. It would be awesome to make a control with tactile feedback. Last edited by Jeff_Rice : 04-05-2003 at 19:46. |
#17
http://www.innovationfirst.com/FIRST...m_Overview.pdf
View Page 4 There are three processors on the Robot Controller. The two of significance are the main processor and the PBasic stamp. The return information is sent back by the main processor. It's the main processor that reads in the analog inputs and sends them to the PBasic stamp. The PBasic stamp only returns the dashboard bits (the LED bits in the code). After the PBasic stamp does that, the main processor gathers all of the information and sends it to the modem to be transported back to the OI. Bottom line, you're thinking good, but you can't do that. The only bits that you can change are the 8 in the dashboard byte and the BasicRun bit. |
#18
Well...
How about using a couple of first or last bits as sigs? ie: 00(2bits +1st part of byte 1) 11(2bits +second part of byte 1) 10(2bits +1st part of byte # 2) 01(2 bits +2nd part of byte # 2) This would take at least .1 seconds to do, but you get two bytes out of the deal. My guess is that your problems arose because of the order in which the bytes and bits are sent. Edit/ You could even do a third byte from the bits Last edited by Jeff_Rice : 04-05-2003 at 21:12. |
#19
Hey everyone. I just posted the code for Dashboard3D http://www.chiefdelphi.com/forums/sh...threadid=20592. Please check it out and, if you still want to make your own dashboard, it could be very useful. It is in total working condition.
| Custom dashboard program available. Interest? | archiver | 2001 | 4 | 24-06-2002 00:45 |
| Need help in creating program to use servo's to shift drive | archiver | 2001 | 19 | 24-06-2002 00:35 |
| miroboworks dashboard program? | archiver | 2000 | 3 | 23-06-2002 23:04 |
| CCISD Updated Dashboard program v2.2.1 | archiver | 2000 | 3 | 23-06-2002 21:57 |
| Yet another dashboard program | Neal Probert | Programming | 3 | 12-05-2002 10:43 |
