Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Go Back   Chief Delphi > ChiefDelphi.com Website > CD Forum Support
Unread 09-05-2003, 20:56
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Originally posted by Ken L
No matter how much math you put into this, the hub and the gear is still one body spinning together. You don't ever see output shaft of motors spin faster or slower than the sprocket attached to it.
It could work, if each of the "gears" were actually planetary gear systems in their own right. The center hub is the axle of the sun gear, the outer teeth are actually the exterior of the ring gear, and the planetaries are hidden under a dust cover the same color as the sun gear axle. Yeah, that would work.
Do I get any extra points on the "Are you a geek?" test for coming up with this interpretation?
-dave
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
