Go to Post FIRST teams are made of people - students and mentors. In my humble opinion, it doesn't make one iota of difference if the name of the sponsoring organization or the name of the school changes over time. - dlavery [more]
Unread 19-05-2003, 10:40
JasonStern JasonStern is offline
FRC #1123 (AIM Robotics)
JasonStern is on a distinguished road
I'm aware that there are 40 channels availible, but doing somre research (including the modem manufactor's website, http://www.electrowave.com/. did you know they make a special modem only for FIRST?) seems to suggest only 5 channels are used. Channel 40 is the default channel, it is the only one you can use without a competition port pluged in. With the port, there are 4 addition channels unlocked. According to the modem manual "While the modem is capable of using 40 channels, only 5 channels are available to the user in the standard modems" The comp port wiring diagram agrees, they give you 5 channels to use (if you manualy select them). If IF does enable all 40 channels for comp, doesn't that mean the mobile modem has to scan through 40 channels looking for a signal <i>every</i/> time as it doesn't know if the extra channels are enabled ahead of time?
Que será será
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
