Go to Post (Don't you hate it...) "when... no more buttons can fit onto your clothing at competitions?" - mcb [more]
Unread 27-05-2003, 17:41
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Next Years Drive Train
Unread 27-05-2003, 17:43
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
THATS INSANE !!!!!!!!!!!!!!!!!!!!!!!!!
wow...
feel bad for anyone who falls in there.... we complain about getting cut with the Drills/Atwoods... imagine that
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 27-05-2003, 18:15
Jonathanb's Avatar
Jonathanb Jonathanb is offline
1037 S.C.R.E.A.M-a-holic
#1037 (S.C.R.E.A.M Team)
Team Role: Driver
Jonathanb is on a distinguished road
Send a message via AIM to Jonathanb
Is that an engine for a ship or boat of some kind?
Jonathan
S.C.R.E.A.M 1037
www.teamfordfirst.org/team1037
2004 Detroit Website Design Award Winner
Unread 27-05-2003, 18:16
Jonathanb's Avatar
Team Role: Driver
That might need some weight reduction holes!
Jonathan
S.C.R.E.A.M 1037
Unread 27-05-2003, 18:55
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
I wonder how many RPM's it can turn???
What do you use as a starter..maybe some 6 liter V8??
Unread 27-05-2003, 19:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Each spark or glow plug must be the size of a person.
Unread 27-05-2003, 19:32
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
search engines are your friends
Just did a little search and found this .
The Wartsila NSD (Sulzer) RTA96-C two-stroke diesel engine is the most powerful and most efficient piston prime-mover in the world today. Bore - just under 3'2" (965mm). Stroke - just over 8'2" (2489mm). Available in 6 through 12 cylinder versions (all inline). Engine weight exceeds 2000 tons in the 12 cylinder version (the crankshaft alone exceeds 300 tons). Point of maximum continuous power is 89,640 HP (66,844kW) at 100RPM with the 12 cylinder version. Point of maximum fuel economy is 53,244 HP(37,704kW)at 90 RPM. The 12-cylinder engine exceeded 100,000 horsepower during overspeed testing (all of 101.5 RPM!) while under test at Japan's Diesel Union works (who built the first engines and from who these pictures are taken). Fuel consumption at maximum power is 0.278 lbs/HP/hour (BSFC). Fuel consumption at maximum economy is 0.260 lbs/HP/hour. At maximum economy the Sulzer engine exceeds 50% thermal efficiency: i.e. more than 50% of the fuel going into the engine is converted to power. For comparison, consider that automotive and small aircraft spark-ignition engines have British Standard Fuel Consumption figures in the 0.40-0.60 lbs/HP/hour range and 25-30% thermal efficiency. Even at its most efficient power setting, the Sulzer 12 cylinder consumes nearly 1,660 gallons of heavy fuel oil an hour.
More Info:
http://www.ihi.co.jp/ihimu/epl/pl07_1.pdf
http://www.marinelog.com/DOCS/twost.html
Have a nice day
Purdue Alumni
Cummins, Inc.
Unread 27-05-2003, 19:56
Ryan Albright's Avatar
Ryan Albright Ryan Albright is offline
Just Browsing
AKA: ryan albright
Ryan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond reputeRyan Albright has a reputation beyond repute
Send a message via ICQ to Ryan Albright Send a message via AIM to Ryan Albright Send a message via MSN to Ryan Albright Send a message via Yahoo to Ryan Albright
wow that is unbelievable. I just cant say anymore then that. excuse me why i go wipe of the drool
Alumni of 710 2001-2004
Mentor 1083 2005
2005 UCF regional lead safety advisor
2005 Championship Safety advisor
Unread 27-05-2003, 22:24
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
can i get one of those for my geo? ill put a turbo and an intake on it, make it all fast, maybe add some nos....
*runs away*
Greg
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 27-05-2003, 22:27
David Kelly's Avatar
David Kelly David Kelly is offline
A Legacy of Impact
FRC #0234 (Cyber Blue)
David Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond reputeDavid Kelly has a reputation beyond repute
Send a message via AIM to David Kelly Send a message via Yahoo to David Kelly
a guy at school showed me that a couple of months ago. pretty sweet
2010 Indiana Robotics Invitational Planning Committee
2010 Boilermaker Regional
Chairman's Award, Regional Finalist
2010 Kansas City Regional
Entrepreneurship Award
2010 Championships
Autodesk Inventor Award Winner
Unread 27-05-2003, 23:35
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
urge to find and steal....rising.....riSING....RISING.....hehe. That is seriously amazing. Jonathanb...the gear closest to the viewer appears to have 5 speed holes...about 3 feet in diameter a piece! Now if we could only fit that into Matt's Jeep.....
Oh and Greg...don't forget....it's gotta have a carbon fiber wing...ooo and hood pins!
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 28-05-2003, 12:09
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
This reminds me of the stuff that they have at the Beatty Machine headquarters that they store for the big steal companies...giant transmissions and gears and stuff. Or the mill that is like 20 feet high and the lathe that you could chuck a person in...
But the machine parts they store are massive like this stuff.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 03-06-2003, 01:56
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
now that we know what it can handle and just about the rest of the specs of it. what it gods creation can actually use that other then a powerplant, some sort of turbo propped cruise ship or something larger.
Im very curious as to what uses that type of engine.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 03-06-2003, 02:33
Andy A. Andy A. is offline
Getting old
FRC #0095
Those engines are used in ships. Really really big ones, container ships.
I guess it's true, 'There is no replacement for displacement'.
-Andy A.
Unread 11-06-2003, 21:29
JAH's Avatar
JAH JAH is offline
My two weeks notice is in...
AKA: Jason Hoff
JAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to beholdJAH is a splendid one to behold
Send a message via AIM to JAH
Looks kinda weak to me....hehe... just kidding...
Jason Hoff
Team 234
jhoff@cyberblue234.com
"Red, White, and CyberBlue..."
2006 Arizona Regional Imagery Award Winner
2006 Arizona Regional Entrepreneurship Award Winner
2006 Arizona Regional Website Award Winner
2006 West Michigan Regional Website Award Winner
We've got 2 Woodies, Chris Fultz and Scott Ritchie.
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
