Go to Post Throw the programmers (or freshmen with duct tape depending on the state of your robot) in the trailer with the robot for the ride between events. Problem solved. :D - ASD20 [more]
Unread 16-06-2003, 00:22
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
By a system of elimination I have concluded the following:
Your motors worked at 4000Hz. Your motors burnt up at 400Hz. Problem - too low of an operating frequency. Solution - move back to the higher frequency.
Now I don't know why the frequency should matter but apparently it does.
As for the performance, it seems to me that it would be better as the frequency increases with a smoother throttle response.
PS. What's so special about these motors that they are so expensive and from overseas?
