Go to Post I check CD while I'm waiting for ProE to reload everytime it crashes. So that's about 20 times a day :ahh: - Gary Dillard [more]
Unread 23-06-2003, 15:13
Matt Reiland's Avatar
'The' drive behind the drive
Doug,
I will get a picture but what we did after Buckeye was take off the sprockets and make some delrin (Actually it was my kitchen cutting board, some kind of plastic) rings that were bolted to each side of the sprocket, they had a steep chamfer at the top that pretty much forced the chain to ride back into the teeth on the sprocket. Unless the chain broke there was no way possible for the chain to derail. Worked perfectly for GLR (We Won!) and at Nationals. This proved to be the most reliable and easy solution to using chains yet. Even better than a tensioner.
Robonaut Next Generation Control System Development
2003 GLR Champions (302,67,226)
2003 Buckeye Semi-Finalists(902,494,226)
2002 Nationals QuarterFinalists
2001 West MI QuarterFinalists
2000 GLR Semi-Finalists
pic: IRI 2003 Belly Check CD47-Bot Extra Discussion 17 24-07-2003 16:49
pic: 2003 IRI - DJ crowning CD47-Bot Extra Discussion 33 23-07-2003 22:48
pic: TechnoKat High School Wall CD47-Bot Extra Discussion 22 22-05-2003 16:47
pic: 2003 TechnoKat Ball Drive : Patent Pending CD47-Bot Robot Showcase 78 30-03-2003 16:27
Image Discuss: TechnoKat Robot 2003 - 2 CD47-Bot Robot Showcase 6 27-02-2003 14:44
