Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
Unread 31-01-2002, 23:07
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
i think i was a little vague in my explanation of our system
we are planning to run a chain from a sprocket on the motor shaft to a sprocket on the shaft with the wheels. Our wheels will be to far apart to drill clear through and attatch the sprocket to both wheels so that they turn together. We need some way of attaching the wheels to the shaft without using a keyway. Were looking for the best way to do this... Oh and we are not using the hubs from small parts. We are using much larger hubs from skyway and of course the wheels that go with them.
One Team, One Bot, One Fleet of Ambulances!
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Motor coupling archiver 2001 19 23-06-2002 23:35
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
