You could also use the dashboard program to figure out which joystick controls each analog input on the port. Just a plug a computer into the dashboard port of the OI, load up the program from IFI, turn on your robot, and move each joystick one at a time. I believe that the names of the inputs your joysticks' control are the y axis, the x axis, and the auxillary axis, but I may be wrong. BTW, you don't need to have working code in your robot to use the dashboard, the OI and the RC just need to have a valid link. Hope this helps and good luck!
| Fried program slots? | Jeff Waegelin | Programming | 18 | 19-03-2003 18:08 |
| robot goes haywire with the one joystick default code | Miles | Programming | 7 | 24-01-2003 14:58 |
| Change to Initializing Inputs and Outputs | Jferrante | Programming | 4 | 07-01-2003 11:36 |
| joystick problem | archiver | 2000 | 12 | 23-06-2002 23:08 |
| switching joystick axis????? | team222badbrad | Technical Discussion | 9 | 16-01-2002 23:07 |
