Go to Post The robot was spinning, I dont have the energy to spin like that. - Joe Menassa [more]
Unread 31-01-2002, 12:01
newy newy is offline
newy is an unknown quantity at this point
Legality of steel tubing.
Is steel (square cross-section) tubing legal? I realise that aluminium tubing is legal, as it comes under extrusion, but does steel tubing count as steel angle, even though it isn't made from angle as such.
------------------------------------------------------------------------------------James Newton
Unread 31-01-2002, 14:49
Bill Enslen's Avatar
Bill Enslen Bill Enslen is offline
FRC #0365 (Miracle Workerz)
Bill Enslen is on a distinguished road
Thumbs up Check SPI
Check the Small Parts, Inc. catalog. I know that they sell Square Aluminum Tubing. They may also sell Square Steel Tubing.
As FRC2001 says, If SPI sells it, then you may use it -- any size, any quantity -- as long as the size you want is in their catalog.
Unread 01-02-2002, 04:00
No, its not in the small parts catalogue, which probably means its not permitted - am I right? The trouble is we'd begun to build our chassis from tubular steel, but luckily not too much before somebody checked the rules - however, we should be able to remake from extruded ali.
Unread 01-02-2002, 09:16
Unhappy
Unfortunately, you are correct since tubular steel is not listed in the additional hardware list. Steel angle up to 2" x 2" x 1/4" is, however you're better off from a weight perspective if you stick with aluminum. If you can find a machine shop near you to weld the aluminum frame, you'll have a solid structure on which to hang your components. Try to get them to donate their time in return for sponsorship of your team. But hurry -- the clock is ticking!
Can you use other tubing? Skabana159 Pneumatics 2 06-02-2003 22:04
steel tubing BBFIRSTCHICK Rules/Strategy 2 14-01-2003 22:03
steel plate ........legal dimensions? archiver 2001 1 24-06-2002 00:32
latex tubing rules?? Christina Technical Discussion 4 21-02-2002 18:43
does small parts sell rectangular aluminum tubing mnkysp6353 General Forum 2 09-12-2001 01:28
