Go to Post It is the team that they build that is the important accompliishment.. - Wayne C. [more]
Unread 01-07-2003, 13:15
cheesinglee cheesinglee is offline
cheesinglee is an unknown quantity at this point
Send a message via AIM to cheesinglee
Question RC resets itself when robot tries to move
This problem popped up after we returned from the Seattle regionals.
Anytime the joystick is moved to move the drive motors, the robot controller will reset itself, often before the wheels even start turning, so I'm quite certain it's not some sort of jarring issue.
Strangely enough, moving the motor for the arm does not present the same problem.
I've tested and swapped breakers, and those seem to be in working order.
Pretty much stumped on this; any help would be greatly appreciated.
Unread 01-07-2003, 13:39
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
The first thing I'd check is that the batteries you're using are properly charged. If the voltage supplied drops below +9VDC, approximately, the RC will reset.
Hmm. Other than this, I'm not sure what to think.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 01-07-2003, 16:12
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Dude, your battery is dead. We had the same thing happen. The drive motors draw much more than the arm motor and will cause a big voltage drop which causes the RC to reset. Leave the battery on an automatic charger overnight or use a manual charger and watch the gauge.
Unread 01-07-2003, 16:51
Electrical Engineer
Rookie Year: 1995
If your battery is good and charged...
Turn off all power. tip the robot on it's side and try and move the wheels by hand. A trashed gear box can give you the same type of response (the controller can reset before the CB trips).
Mike Betts
As easy as 355/113...
Unread 01-07-2003, 18:10
Sully Sully is offline
no team (The Bobcats)
Rookie Year: 1994
Sully is on a distinguished road
Send a message via Yahoo to Sully
Assuming you have tried everything mentioned above and still have a problem. I would think about the joystick - it may have a short or a loose connection. Try another joystick. Inspect the port on the OI.
Unread 01-07-2003, 18:18
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
like everyone else has pretty much said, charge the battery, check the joystick to see if theres a short. And check to make sure the oi pins on the comp port or any port are not damaged, you could have a short also somewheres in your bot thats causing a chrge to build up and create an impulse to the comp port. Also take a voltmeter and make sure you are getting flow to the motor, then you will definitly know if it is an electrical or mechanical problem... Other then that blame the programmer (j/k).
~Mike
P.S.~ the prgramming joke is that if its not mechanical then its got to be programmings issue...
-Michael Dessingue
Unread 01-07-2003, 18:47
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Originally posted by dez250
....Other then that blame the programmer (j/k).
~Mike
Don't blame the programmer! It sounds like you're having a short circuit or something similar. Just get the multimeter out and start poking around.
Matt Krass
Unread 01-07-2003, 19:59
Elgin Clock's Avatar
FRC #0237 (Black Magic)
MOVE THE RADIO!!!
That was our HUGE problem this year!! We found out where we mounted the radio on the robot caused a huge RF interference problem which led to us doing the same exact thing at NYC this year!!
Move the radio!!
If that doesn't work.... rebuild the robot!! lol
Unread 01-07-2003, 21:33
thats what i was poking fun at...yeah like matt said, just strt probing the bot with a multimeter and see if the readings you get back are normal, if they arent, then you found the problem(s).
~Mike
-Michael Dessingue
Unread 02-07-2003, 13:30
Umm Errr...
It sounds like you may have a short somewhere after a speed controller. As mentioned earlier, it might be posible that a short in the leads between a motor and a speed controller could draw enough current to drop the system voltage beyond the RC reset point before a breaker has time to trip. What happens if you only push the stick forward slightly? Check the resistance between the motor terminals and the M+ and M- terminals of the speed controlers to the V+ and V- terminals. What are they?
[EDITED TO CORRECT MY DUMBNESS.]
1139 Alumni
Unread 02-07-2003, 15:47
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Originally posted by Rickertsen2
Disconnect the motor leads from their speed controller and touch them directly to a battery. This will rule out the motor and drive train.
DON'T DO THIS! If there is a short and if it is in the motor (which is definitely possible), you will be causing a direct short across the battery terminals with no circuit breaker/fuse in between for protection! In addition to probably welding the motor leads to the battery, you can damage the battery, the motor, and even possibly start a fire.
Unread 02-07-2003, 16:09
Don't do that at all!!!!! With in doing that, you will not only happen to ruin the motor or battery, but if there is a shirt in the motor, this is the same thing as just placing a solid wire across two battery terminals, that will cause a short. Also with a short circuit on a battery directly, this can cause the battery to have too much current flowing through it and will cause the battery to most likely explode and or ignite on fire... Common physics and electrics never make a direct connection across a battery without a breaker or an output with resistance in series.
~Mike
-Michael Dessingue
Unread 02-07-2003, 22:36
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
I have done this before besides a little bit of sparks nothing really was destroyed. The only time you risk destroying a battery from hooking it up to a motor is if you stall the motor. Then again stalling the motor is just as likely to destroy the motor before the battery. It seems very hard to make an SLA acid battery explode. I have read horror stories about people abusing there batteries and all the battery would do is stink, and expand a lot.
Unread 02-07-2003, 22:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
That's assuming the motor is in good working order. If it's shorted internally (if the brushes shomehow fell off and landed in the wrong place, etc), it's virtually the same as connecting a wire between the two terminals. Yes, the sparks are very pretty, but it really isn't worth it...
Unread 02-07-2003, 22:58
Adam Y.'s Avatar
Adam Y.
no team (?????)
You really can not blow up a SLA battery. I have read quite a few posts where people have accidently shorted out there SLA's and all the end up doing is expanding.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
