Go to Post If only 5% of American entry level workers are proficient in algebra in 2022, I'm moving to Canada. - PVCpirate [more]
Unread 03-07-2003, 14:34
Umm Errr...
Originally posted by Adam Y.
That is odd my books tell me you can't measure resistance of a motor using an ohmeter. I really do not know why though. Try getting a few D alkaline batteries or a regulated power supply.
Your books probably say that bacause motors have a very high inductace and will have dirrerent resistances depending on a number of conditions such as mechanical load, frequency, etc. At the very low DC voltages used by most ohmeters, the inductance is negledgable and an ohmeter can be used to test for shorts if you know the resistance of a good motor of the same type. And by the way i use an variable current limited bench power supply to test motors.
1139 Alumni
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
pic: Ball Drive Close Up CD47-Bot Robot Showcase 17 04-03-2003 15:23
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
