Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 05-07-2003, 03:38
FRC Key Volunteer Trainer
AKA: CrazyNate
The Trick to Dual-Booting
In order to get things to work right, install Windows FIRST, then linux...after windows is installed, it won't touch the MBR unless you tell it to...and the linux boot loader(LILO or GRUB, depending on your distro) is smart enough to recognize a windows partition.
Also, MAKE A LINUX BOOT FLOPPY!!! In the event that something within windows messes with the MBR, causing you to only be able to get into windows, a linux boot floppy will allow you to reinstall LILO or GRUB. I know mandrake's setup tool gives you a chance to create one during the linux install, i can't speak for any other distros however...
However, sharing partitions is a bit trickier...as of the last linux distro I played around with(Mandrake 9 or 9.1 i believe), NTFS support was read-only. So, if you want to be able, for example, to modify files in your windows "My Documents" folder from within linux(i.e. using OpenOffice,) your windows partition will need to be FAT32. Unfortunately, without a third party tool such as partitionmagic, you can't convert an NTFS partition to FAT32 without recreating the partition, which causes you to lose all of the data in the partition.
Nate Smith
nsmith@smythsoft.com
autocad release 14 useable with windows xp? northendchopper Inventor 1 25-11-2003 16:48
Linux And Windows XP Raven_Writer Chit-Chat 4 06-08-2003 18:53
Windows XP Partition is Odd Yan Wang Chit-Chat 6 05-07-2003 23:30
Home Networking on Windows XP D.J. Fluck Chit-Chat 16 14-09-2002 14:21
New Windows.... Clark Gilbert Chit-Chat 12 31-07-2001 15:43
