Go to Post This year it is what it is and, at some point, we will all find out what that is, specifically. - JaneYoung [more]
Unread 13-07-2003, 12:20
rlowerr_1's Avatar
rlowerr_1 rlowerr_1 is offline
#0930 (M³)
rlowerr_1 is an unknown quantity at this point
Send a message via AIM to rlowerr_1
This is not exactly how the technokats works. On the technokats the two output gears are not attached to the shaft. As far as I can tell they rotate freely around the shaft until the dog is shifted inside the gear thus spinning the output shaft at that gear ratio.
I would assume that my Lego version works because of the size, number, and spacing of the teeth. If you had gears with more teeth it would seem that it would have a harder time at meshing the gears.
I’m no expert at mechanics… just LEGO! My strong point is more on the initial concept and design, not the final product.
pic: 2 speed shifty on the fly Lego Bot CD47-Bot Robot Showcase 9 31-01-2005 04:21
Team 294's Lego League Teams Redhead Jokes FIRST Lego League 0 24-11-2003 17:21
pic: LEGO Vernier Gearbox CD47-Bot Extra Discussion 9 10-10-2003 09:43
LEGO Biped Project rlowerr_1 Robot Showcase 23 07-09-2003 14:21
LEGO League David Kelso FIRST Lego League 10 03-01-2003 18:24
