Go to Post Sports have the power to change culture in a way that games do not. - Nate Laverdure [more]
Unread 03-02-2002, 09:06
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
Crates At Regionals
Are we allowed to bring our crate, and use it as a workstation.
In regionals?
At nationals?
FIRST made a ruling on this (I think) saying that you could NOT bring a crate into the PIT due to space constraints.
Whats the real deal? Should I tell my team to unload our crate full of tools and stuff, being that we cannot use it as a workstation?
Citation of the actual rule would be greatly appreciated.
Thanks for your help.
--Ben Mitchell
Unread 03-02-2002, 21:24
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
[Question: May we use a "foldout crate" as a workstation in the
pit?]
A) This would be allowable if it will fit inside of your allowed pit space (and the pit spaces are not very big). We also assume that
you will not be doing machining or other potentially hazardous work from this workstation. That is why we have machine shops available to help you. FIRSTsnow
We too may wish to consider a foldout crate/workstation, but need more specifics. When you say "the pit spaces are not very big", that's a bit vague. It doesn't give us enough info to figure this out. Can you please define that a little more precisely?
IMHO, the best way to answer to allow us to design
crate/workstations would be if you could please specify one of the following:
1) The minimum pit space dimensions [W x L] each team will be
allocated, along with which "face" will be the entrance & exit side or aisle,
**OR**
2) A maximum combo crate/workstation dimension set that you feel will safely work in the planned allocated pit area, if less then the original shipping crate maximums. Assume the crate will be set on one of its sides so we get a "long table" effect.
A) First, pit station dimensions are different at each venue. We
cannot give you exact dimensions. The LARGEST you can count on
(except for Epcot) is 8' x 8' and it might be a bit smaller or it
might not be square. Everything you bring with you including your
robot, team members, and your crate/workstation (if you think it will fit) must fit within thnat space. That's not to say that team
members don't occasionally spill into the aisles but the aisles must be left open in case of emergency. FIRSTsnow
From message 536? on the yahoo group. Seems to me the answer is yes.
Viva Olancho!
Unread 04-02-2002, 02:08
mnkysp6353's Avatar
mnkysp6353 mnkysp6353 is offline
no team (Bagel Bytes)
mnkysp6353 is an unknown quantity at this point
Send a message via AIM to mnkysp6353
Well thats good. Team 64 had a great tool crate. If they could post a picture of it that would be great, also if any other teams have great crates please post.
Unread 04-02-2002, 11:21
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Don't center your workstation around the crate. Make another one and the crate because sometimes they don't care and take it away from you even if you use it for your workstation.
Unread 04-02-2002, 13:25
Wetzel's Avatar
DC Robotics
Yes, unless you unfold it in such a way as they can't use the pallet lifter to move it, leave a clear note for them to leave it.
Viva Olancho!
Hey FIRST - We're going to need a lot more regionals! Raul Regional Competitions 41 08-11-2003 18:10
crates ivanslost Rules/Strategy 1 12-02-2003 21:50
Chief Delphi went to three regionals? FIRSTfan General Forum 12 08-04-2002 11:07
crates at regionals Ben Mitchell General Forum 1 02-02-2002 17:32
VCU and KSC regionals Manoel Regional Competitions 0 25-09-2001 13:44
