Go to Post Umm, guys, the stacking game was last year. Toss the Genia is much more appropriate for Aim High. - Greg Marra [more]
Unread 04-02-2002, 08:51
Dr.Bot
Posts: n/a
I haven't looked at the switches yet, but did your try swapping
pressure gauges? Also what is the measured output on the compressor regulator - Ours certainly was tripping at 120 and the
secondary was at sixty. Find it hard to believe both swtiches were so far off. I am not sure if the switches are adjustable.
I also noted (much to my chagrin) that there were many leaks the first time I put the system together. Especially at the pressure tanks. Getting the teflon tape right takes a little practice.
Use a spray bottle of soapy watter to test your connections.
pneumatic system pressure illumanat'i Pneumatics 6 31-01-2003 00:46
Quick Optical Sensor Question zorro Technical Discussion 10 21-01-2003 06:39
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
