Go to Post Thanks to ... Dave, who teaches us not to worry, it’s only rocket science. - JohnBoucher [more]
  #38   Spotlight this post!
Unread 24-08-2003, 21:01
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
Ah, yes obviously java is slower. But the javelin stamp processes 8000 commands per second apparently (parallax.com). I think that would be sufficient enough for what we need. Well, I wouldn't consider C++ simplier. I would rank level of difficulty from C to C++ to Java being the easiest. C'mon to go to the next pointer in java isn't it like list.nextPtr();. Also, you might not realize how much actual support parallax has for the javelin stamp, in documentation, function lists with examples and descriptions parsed nicely, and several examples. It's actually pretty nice. It all depends how the code is stored and processed, they could compile the java code or not. I haven't read up enough on the javelin stamp to tell you.
R
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
2004 Championship Eligibility Criteria!!! dez250 General Forum 214 28-12-2003 20:11
Championship Qualification - How you would've done it Ken Leung Championship Event 6 26-10-2003 14:00
Making heads or tails of the new announcement... Jessica Boucher General Forum 66 26-09-2001 11:13
TI programming using Z80 assembly language Jeff Wong Chit-Chat 1 07-06-2001 01:27
