Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
Unread 06-09-2003, 11:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Originally posted by Tytus Gerrish (in the caption for this picture)
It SO! works
With a standard, and a micro lego motor, tested using my fingers as a load
with an unmovable load the motors don't Overpower each other they just stall and don't move. NO moving bakwards
i admit these are just legos and a true test is required
Tytus, do you have the rpm and power on hand of each of those motors (i.e., how similar are they)? I'm curious as to whether the differential was actually working as anything but a fancy shaft (if the speeds were identical, the housing of the differential would rotate, but the bevels inside wouldn't turn--hence, a shaft).
If the differential were matching speeds, then you might be at risk of stalling one or the other (as Bill Beatty suggested in the other thread), depending on the conditions of the test (e.g. relative power and relative speed of the motors--speed would have to be different, and power similar). You should also note that these are small brushless motors. Stalling these is no problem, but on the FIRST robots, the motors are not nearly so pleasant when they are stalled.
In short, while it may work now, it probably isn't an accurate enough simulation of a Bosch 3360 and a CIM FR801 (like you admitted...).
-Tristan Lall
pic: Coaxial Lego doubble-wishbone crab CD47-Bot Robot Showcase 7 10-12-2003 12:10
pic: poor mans Lego Coaxial crab CD47-Bot Robot Showcase 8 23-10-2003 22:00
pic: LEGO Vernier Gearbox CD47-Bot Extra Discussion 9 10-10-2003 09:43
pic: lego Planitary... Kinda CD47-Bot Extra Discussion 5 14-07-2003 23:55
pic: Lego Swerve Drive CD47-Bot Robot Showcase 14 26-06-2003 16:19
