Go to Post I gave up football and a chance to be ignorant the remainder of my hs career....so ive gained more than loss - TheNotoriousKid [more]
View Poll Results: Should Weigh in be With or Without Battery
With 31 55.36%
Without 19 33.93%
Weight Limit should be increased to make things more exciting. 6 10.71%
Voters: 56. You may not vote on this poll
Unread 07-09-2003, 04:26
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: I must admit...
Originally posted by Mike Rush
If we were close at weigh in, we would weigh all of our available current year batteries and choose the lightest one. This helped us a little and also fell well within the spirit of GP and FIRST.
I think many teams did this exact thing. Using a "lighter, Real Battery" is much different than a "dummy". It's completely legit but at the same time unfair to those teams who get stuck with the heavier batteries.
I have seen a ~2lb difference (12.2lb - 14lb) between some batteries. 2lb's is a lot of speed holes if you don't have the "right" battery to weigh in with.
My suggestion:
Rule: Battery must be easily removed in under 15 seconds.
Reasons:
1) Very few designs have broken that
2) Easy for battery removal weigh in after Systems check.
Team shows up, does all the tests (lights, air, etc.), then gets timed for battery removal, then weighs in without putting the battery back in.
This alleviates the 'dummy battery' problem, battery weight flux problem, and gives grounds for "changing" weight limit. Be it, "lower" to 120lbs [no bat] or "keep" at 130. (Keep in mind 12-14lbs + for battery when on field)
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
