Go to Post While we discuss this stuff, let's keep our heads on straight. Open your eyes and look around you. Let's celebrate our common goal while accepting our differences. - Andy Baker [more]
View Poll Results: Should Weigh in be With or Without Battery
With 31 55.36%
Without 19 33.93%
Weight Limit should be increased to make things more exciting. 6 10.71%
Voters: 56. You may not vote on this poll
Unread 07-09-2003, 21:40
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
If any of you remember when we moved from the drill batteries to the current batteries the weight limit was increased 10lbs to be able to keep the weight limit the same. So there is no real reason to change the weight limit or weigh in without a battery.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
