Go to Post Yes, it is fun. Its fun to watch the students expand their thinking and look outside the "normal" and watch their thoughts explode! Its also fun to watch the mentor's minds fry trying to out think the students.;) - Robert Cawthon [more]
Unread 09-09-2003, 08:58
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
I am planning a white paper detailing the shifter mechanism within the next two months. I will include gear ratios and main plates in the write up.
In the meantime, The approximate weight without motors is 5 lbs. This is only an estimate as I forgot to do a weight check.
The output speed at the shaft is 162/684 rpm for low/high. We reused the gear on the CIM and the sprockets from the output so this dictated some of the ratio decisions.
This box is 2-5/16" wide by 2-3/4" tall. I am guessing it to be about 7" long, I left the file at home. The plates are 1/4", the ouput bearings are not flanged so the button heads keep them in.
I have been running flat out the last few weeks at work so I am a little behind on everything. I will answer questions as fast as I can.
White Paper Discuss: Dual Motor Gearbox - 2003 CD47-Bot Extra Discussion 6 08-04-2004 19:46
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
pic: LEGO Vernier Gearbox CD47-Bot Extra Discussion 9 10-10-2003 09:43
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
