Go to Post Unfortunately, not everyone is Andy Baker. If everyone had this mindset, there would be far fewer problems. - Kevin Kolodziej [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 15-09-2003, 20:43
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Official - Mike Martus Goal 9/15
Many persons have asked about the dimensions on the goals.
Justin is working on a better list of measurements.
I have built both goals and have some insight:
1. Not all 3/4 plywood is 3/4. Did you know that if the plywood is from Canada it is metric and smaller by almost 1/16.
2. Not all 2 X 4 are 1 1/2 X 3 1/2. They vary as much as 1/8 depending upon the mill they were from.
This means that you may have to tweak your goal a little to get the desired effect.
Justin will post the exact model of caster from Home Depot. Casters vary as much as 1/8 in height and still be called 3" Casters.
Add to that the differences in fittings, even within the same box.
Please remember: If you build a robot that is critical to a dimension you may be in trouble because of the many variables. Design for a range of sizes. That is why all sizes as plus or minus 10 inches
Mike Martus
Unread 16-09-2003, 23:16
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
The actual goal dimensions
As Mike Martus said, dimensions will vary slightly on many materials. If you want to take a look at the actual goals that are to be used, every team is welcome to come by and see the goals themselves at OSTCNE. Call me at 248-451-2732 to set up a time. I'm going to try to find a site at the south end of the county where we can leave two of the goals to save on drive time.
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Goal Order Team573 OCCRA 2 17-09-2003 21:35
Official update #1 - 9/13 - Mike Martus Mike Martus OCCRA 0 13-09-2003 21:48
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Thanks Team 47 / Mike Martus archiver 2000 0 23-06-2002 23:03
