So this is an ASP and PHP only thing? No perl for example?
No, no! Well originally I thought we should base our energy to ASP/PHP development. If someone knows another language very well and would like to create the openFIRST equivelant for it then your welcomed to go ahead.
The way we would handle multiple language development would be to use the same repository for every language, except every module will be set apart with -[language name]. For example base-asp/ or messenger-perl/ or members-aspnet/.
Note that if you decide to lead the development for creating openFIRST in another language you will be responsible to handle its completion, and website management. You will get support from the rest of the team but you will act as the main "hub" of communication for development.
Note that you will also be completely credited for any work that you do complete and your team and name will be recorded as a founding-member.
If you are interested you may contact me directly, so that I may set you up with a sourceforge account and access to the CVS and openfirst.sourceforge.net http site.
