Go to Post I'm here to unintentionally offer insightful quotes. - Jeff Waegelin [more]
Go Back   Chief Delphi > Other > Dean Kamen's Inventions
Unread 25-09-2003, 19:04
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Do you have any specifications on the motors? All you need to know is max RPM and stall torque and you can find it out.
Power output= free speed/2 (RPM) * stall torque/2 (Nm) * 2pi/60 (unit-related, do a google search for motor power)
Electrical Input Power = Voltage * Stall Current / 2
Power output is always the highest at 1/2 the free speed / stall torque. The 2pi/60 is to convert RPM to rad/sec. Additional conversion factors are needed if the torque is not expressed in newton meters.
The torque and speed can be adjusted accordingly using gears, all we need to know is the power output of the motor (not power input, which is voltage times current).
EDIT: Fixed power equation.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Would this balance? MattK General Forum 9 16-04-2003 20:11
traction vs turning HEPL andy Technical Discussion 2 10-02-2003 22:51
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
Mentor/Engineers - Robotics vs. Work Balance Scott Wolfe General Forum 13 16-04-2002 12:05
