Go to Post (You know you're overdosed on FIRST) when watching regional web-casts takes precedent over Saturday morning cartoons. - Hawiian Cadder [more]
Unread 01-10-2003, 09:35
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
I'm interperting your request as if you have a joystick, and you want to be able to press a button on it to slow down the robot, in order to make it more controllable.
If this is what you're looking for insert this write after the code block where you tie the p1_y and p1_x (or whatever vars you use) to the pwms:
if (p1_top = 1) then
if pwm1 > 127 then pwm1 = (pwm1-127) / 2 + 127
if pwm1 < 127 then pwm1 = (127 - (127-pwm1) / 2)
endif
Do the same for pwm2. This will reduce the speed of the robot by a factor of 2 when p1_top is pressed.
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Prgm4 2 joystics control 1 speed cntrl??? punarhero Programming 7 21-02-2002 09:57
speed control punarhero Technical Discussion 11 24-01-2002 18:03
