Go to Post Defense will be everybody's part time job, not their career. - Wayne TenBrink [more]
Unread 07-10-2003, 10:04
Joel J's Avatar
Joel J Joel J is offline
do you..
Originally posted by Trashed20
now that i think about it, you wouldn't need a new line return. when you write out things like that on a chalk board you go all the way across and down, so no new line is needed
I will not throw paper airplanes in class. I will not throw paper airplanes in class. I will not throw paper airplanes in class.
Lol, but there is also no space at the end of the line:
I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.I will not throw paper airplanes in class.
...nitpickers
Joel Johnson
RAGE (173) Alumni, 1999-2003
What is your most prefered programming language? Hailfire Programming 156 19-01-2005 21:42
Open source Jeff_Rice Programming 16 25-03-2003 23:40
Autonomous code PBoss Programming 7 14-01-2003 15:29
Does your team use the Default code. Jeff McCune General Forum 2 09-01-2003 14:46
Patent source code? Kyle Fenton Chit-Chat 3 20-10-2001 17:53
