Go to Post I'll toss this out to stir up the pot: if you need double precision floats for your FRC software, you should re-think what you're doing. - Ether [more]
Unread 10-10-2003, 23:05
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
Lightbulb Making a series of spaced holes around a cylinder in inventor
In Inventor I know its possible to make a series of equally spaced holes around the surface of a cylinder, but how? When I try Inventor won't let me select the curved surface of the cylinder.
Unread 10-10-2003, 23:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Try in the browser window on the bottom left clickint the plus in front of the origin folder. Then select features in the panel bar. Then select the Work Plane tool. Then select the plane you want under the Origin folder in the browser. Then click sketch and you should be able to use that plane.
That one I learned from Clark Gilbert on 45.
Unread 10-10-2003, 23:25
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
"of 45" mentally, not physically anymore
The easiest thing to do would be to make one hole then "Revolve" it around the surface of the cylinder.
Purdue Alumni
Cummins, Inc.
Unread 11-10-2003, 17:20
James114's Avatar
Ya i know how to make stuff "revolve" around a flat surface, but i don't know how to start a hole on the curved surface of a cylinder.
Unread 11-10-2003, 17:59
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
You need to make a work plane that's tangent to the cylinder. Then, create a new sketch on the plane and draw your hole. The hole will then cut into the cylinder.
If you're lucky, the intersection of two of the origin planes lies along the center of your cylinder. In that case, create a new work plane by clicking on one of the origin planes and dragging it away -- it'll ask you for an offset distance. That distance should equal the radius of your cylinder.
If you're not that lucky, you can fudge things a bit -- but how much depends on how accurate you need the whole depth to be. To do that, just drag a new work plane out beyond the edge of your cylinder. The features you create on that work plane will still affect the cylinder.
Then, create a circular pattern of that hole around the rest of the cylinder.
--Madison--
...down at the Ozdust!
Unread 11-10-2003, 18:21
James114's Avatar
How I do It
That sounds good, but when I have had to make a series of hole in a cylinder, I have used the polygon tool, so if I need 8 holes I make an octagon, and then make the holes uniformly on each of the 8 sides. Then create a circle at the base of the octagon and extrude away the excess material.
Unread 11-10-2003, 18:45
Madison's Avatar
FRC #0488 (Xbot)
Re: How I do It
That works, too. Of course, it's no good to you when you're adding holes to a pre-existing cylinder
--Madison--
Unread 11-10-2003, 19:38
James114's Avatar
Thats true, but i normally make all my own stuff from scratch unless its really complex
Unread 25-08-2004, 14:05
JDPhillips JDPhillips is offline
JDPhillips is an unknown quantity at this point
Re: Making a series of spaced holes around a cylinder in inventor
I want to place holes around a cylinder as discussed in this thread, but I need to make them _parametric_, so that I can slide them around after drawing them, both along the cylinder axis and in azimuth. I do not need to change the number of holes after drawing them.
This seems to contradict an Autocad paradigm, that one establishes a sketch plane which is *not* adjustable parametrically, and works parametrically in it. Is my impression correct, and does anyone know a workaround?
For example, I can put a sketch or work plane perpendicular to the cylinder axis, but I don't know how to set up an adjustable dimension between that plane and the cylinder base. Further, I don't know how to make holes without a work plane perpendicular to each hole, at least perpendicular to the first hole of an array of holes. And I don't know how to set up an adjustable angular dimension to the first hole of the array.
I'm using Mechanical Desktop 2004 DX, but I'm not wedded to it, and if someone convinces me that this is easy in Inventor, I'll learn enough of that to do the job.
Thanks.
Jim
Unread 18-11-2004, 10:21
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
I use AutoCAD 2002, and what I believe you will want to do in CAD 02 is extrude a circle of desired diameter to desired height, and then create a negative cylinder the size of the hole that you want in the original cylinder, then array the negative around the original at 45 degrees increments. Then you can subtract the negatives from the original and have holes in the original cylinder.
*sarcasm* That's just my opinion, not like I do CAD just for the fun of it or anything. */sarcasm*
Squirrel
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 18-11-2004, 18:45
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Thanks.
Jim
My AUTOCAD is pretty rusty, but here's how I'd do it in Inventor:
1) Construct the first cylinder by extruding along an axis. For convenience I'll use the Z-axis.
2) Construct a work plane that passes through the Z-axis and at an angle to the Z-X plane. Call it 30 degrees.
3) Create a sketch on the work plane. In the sketch, create a circle of the desired hole diameter and center it on the Z-axis. Project the bottom of the cylinder onto the sketch plane. The resulting line should be perpendicular to the Z-axis. Dimension from the projected line to the center of the circle.
4) Extrude and subtract the sketch with the circle. Be sure to extrude farther than the radius of the tube.
5) Use the circular pattern command to create multiple copies of the hole rotated around the Z-axis.
If you want to change the height of the holes from the bottom of the cylinder, change the dimension in the sketch. If you want to adjust the azimuth of the first hole, change the angle on the work plane. If you want to change the number or spacing of the holes, edit the circular pattern command.
ChrisH
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-11-2004, 10:54
I want to place holes around a cylinder as discussed in this thread, but I need to make them _parametric_, so that I can slide them around .. I'm using Mechanical Desktop 2004 DX, but I'm not wedded to it, and if someone convinces me that this is easy in Inventor, I'll learn enough of that to do the job.
Thanks.
Jim
Jim,
In Mechanical Desktop you should be able to generate the holes the same as you would in Autocad but with "associative" properties. Those objects should be able to move with respect to other objects in the drawing and the dimensioning should also autoupdate to reflect changes.
In Autocad I would set a UCS that is perpindicular to a tangent on the cylinder. (This is a simple operation which is easy to see if you are using a 3D view.) Then draw a cylinder of the size needed for the holes in the first cylinder with one end inside and the other outside of the first cylinder. You now have two cylinders intersecting each other. Using polar array with the center of the first cylinder as your center point of the array, generate a number of cylinders that matches the number of holes you need. You now have one cylinder that is pierced by several other cylinders. Now using the "subtract" command, use the arrayed cylinders to cut holes in the first cylinder. All of the arrayed cylinders will disappear leaving the holes you need.
I would block the polar array objects first. That way you can use the block to fill in holes if they don't appear where you want, (use the "Union" command) and then place the object whereever you need the new holes.
Unread 19-11-2004, 20:21
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Originally Posted by Al Skierkiewicz
Jim,
Al,
Now you did it - forget that electrical stuff - you're on the mechanical design team next year!
Raul
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 21-11-2004, 18:44
Raul,
That's Autocad, not Pro-E
I offered before but NOOOOOOO! So I stay on the electrical team.
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
