Go to Post ... if there is no standard against which you determine success, then you can never fail. - dlavery [more]
Unread 11-10-2003, 18:21
James114's Avatar
James114 James114 is offline
FRC #0114 (Los Altos High School)
James114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really niceJames114 is just really nice
Send a message via AIM to James114
How I do It
That sounds good, but when I have had to make a series of hole in a cylinder, I have used the polygon tool, so if I need 8 holes I make an octagon, and then make the holes uniformly on each of the 8 sides. Then create a circle at the base of the octagon and extrude away the excess material.
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
