#10
robot speed (ft/s) = (wheel rpm * pi * wheel dia) / 12 / 60
Dividing through the rpm as you go from gear to gear usually gives you less errors since you could do the total ratio wrong. And don't use the free speed, just the normal load speed of the motors. Last edited by Rob Colatutto : 12-10-2003 at 14:03. |
| 1 stick drive to 2 stick drive | wayne 05 | Programming | 18 | 01-04-2004 16:41 |
| center-wheel drive | Mercutio | Technical Discussion | 27 | 02-02-2004 21:19 |
| how does crab drive work? | Soukup | Technical Discussion | 13 | 25-04-2003 11:31 |
| Direct drive or Chain? | Suneet | Technical Discussion | 32 | 27-03-2003 23:00 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
