Go to Post According to that logic, Engineers would say there will be twice as many spectators as needed, and we all know that's not the case! - Taylor [more]
Unread 12-10-2003, 14:09
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally posted by Rob Colatutto
And don't use the free speed, just the normal load speed of the motors.
I usually use the free speed, then just put in a 15% "speed loss" to compensate for drive friction. It is hard to pre-determine the load a motor will see from the gearbox itself (the only load acting on the motor when it is running straight out across the field).
Otherwise, Rob, Matt, AND Jnadke have the formula right, the only thing you need to take into account is unit conversion. (personally, I prefer doing it all in metric and RPM, then converting to fps and lbs at the very end).
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
