Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 17-10-2003, 22:16
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Post
Tower hobbies listing of radios
http://www.towerhobbies.com/listings/cat-cat-j.html
most r/c vendors also refer to "channels" when you buy your radio this is what lets you select the frequency at which it will operate this link specifies the various channels
http://www.towerhobbies.com/help/frequencies.html
for our uses we need surface channels (61-90)
as for brand I recommend Futaba also the tower hobbies brand of radios seems to be constructed by futaba and from what i have seen are good quality. Ni cad batteries are included with most 4 channel systems (good thing I never seem to have enough AA batteries to operate the one radio I have that doesn't use them) or you can use normal AA batteries.
However you may need to make or buy some adapter cables to connect your receiver to the edu-rc I'm not sure of the brand of the cables used by IFI but i think they may be jr style? (its been a few years since Ive bought a radio)
EDIT:
according to IFI page 6
http://www.innovationfirst.com/FIRST...10-15-2003.pdf
The voltage fromt he full-size FIRST Robot Controller PWM OUTPUTS is too high and will damage the EDU RC, voiding your warranty
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
goals: how much control? Pat Sarmiento Rules/Strategy 2 18-01-2002 19:10
