Go to Post I do know that I cringe every time someone brings up "lawyerism" or some other such nonsense as the reason their interpretation of the rules is right. - Kris Verdeyen [more]
Unread 10-02-2002, 17:35
thedillybar thedillybar is offline
#0894 (Chargers)
thedillybar is an unknown quantity at this point
Send a message via AIM to thedillybar
Calibrating speed controllers and joysticks
Do we need to calibrate both the speed controllers and joysticks? I know how to calibrate the joysticks but I'm not sure how to calibrate the speed controllers.
Also, since the speed controllers have this "built-in" deadzone, we should just use this:
PWM1 = p1_y
instead of:
if p1_y>117 and p1_y<137 then skip1:
PWM1 = p1_y
skip1:
Thanks.
Unread 10-02-2002, 18:46
Andy A. Andy A. is offline
Getting old
FRC #0095
Go to the , Innovation First website and check out the victor 883 user manual.
My one question is this: The victors come precalibrated, why do you need to recal?
-Andy A.
Unread 10-02-2002, 20:32
The Victors come precalibrated for the expected out range from the RC, andy, but there may be enough variation in the joysticks at both ends and the middle, that you might want to consider checking the values sent at these positions.
Unread 10-02-2002, 22:50
Adam Krajewski's Avatar
Adam Krajewski Adam Krajewski is offline
AKA: Jewski
None #0857 (Superior Roboworks) / Team #0068 (Truck Town Thunder)
Adam Krajewski is on a distinguished road
The speed controllers haven't needed user calibration since the Tekan (spelling?) days. The only time I've ever found it necessary to re-calibrate the Victor 883s was to regain the default calibration. All other calibrations should be done via the joystick. The pots in the joystick, however, aren't always perfect. Far from it, in fact. I use a debug terminal to check the range on the joysticks and, if necessary, adjust their value using software.
Adam
Unread 11-02-2002, 13:24
CaptainPlaid's Avatar
CaptainPlaid CaptainPlaid is offline
#0314 (Megatron Oracles "Big MO")
CaptainPlaid is an unknown quantity at this point
Recalibrating the Victors as opposed to doing it in the software can be a problem. If you ever have a Victor fail you have to try to get the new one to match the calibration of the old one. If you do the trimming in the software you can just swap it out and be ready to go.
Remember Victors don't like metal chips much although they have been much better about it since last year.
I have not failed. I have just found 10,000 ways that won't work.
Thomas Edison
control box archiver 2000 8 24-06-2002 00:20
