Go to Post Yes ONE blue banner would be nice one of these days, but I've never lost focus of why we as mentors do what we do. It's about preparing the students for "defense" in life, and laugh when your robot gets scored into a goal. - Chris_Elston [more]
Unread 05-11-2003, 23:08
Burgabot Burgabot is offline
#1067 (Junior Billikens)
Burgabot is an unknown quantity at this point
Actually, I do have another question. Originally, I was going to measure angular velocity by integrating angular accleration, obtained from two linear accelerometers placed a certain distance apart. I did this because the gyro can only measure angular velocities of ±75 degrees/second or less, and runs into trouble at anything higher than that. However, I realized that this will be far less accurate than using a gyro sensor.
Basically, what it comes down to is that there's a tradeoff between accuracy (the gyro) and range (the two acclerometers). Therefore, I came up with a compromise that I hope will work. In every program cycle, I'll get the angular speed as determined by the gyro. If it turns out to be 75 degrees/second (which I'm assuming is what it'll return if the speed is higher than that), I'll use the accelerometer data instead of the gyro data to determine the angular velocity. That way, I'll have the accuracy of the gyro at normal speeds and the range of the accelerometer arrangement at high angular speeds. Think this will work? Anything I have to watch out for?
Quick <hr> question Jack Website Design/Showcase 1 31-01-2003 22:19
To all the ladies in the hiz-ous!! lol a quick question archiver 2001 1 24-06-2002 02:12
Quick Question archiver 2001 5 24-06-2002 00:08
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
Quick Question, i guess Andrew Rudolph Motors 1 12-08-2001 14:39
