Go to Post Robotics is my football! - Nemo [more]
Unread 07-11-2003, 08:59
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Dual-Speed Drive Module
Unread 07-11-2003, 09:04
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Hey M.
Looks interesting! I actually haven't seen that type of drive-switching mechanism before, we (639) implemented a vaguely similar idea for 2002. I'm kind of confused exactly what it's intention is, maybe you can elaborate for my slow mind? For example, why are there two omniwheels? This would result in a robot with 4 omnis touching ground right? I'm also curious why the rollers of the wheels are slightly staggered. So yea, I'm just interested to hear a summary of what it does
Hope you're enjoying Seattle!
- Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 07-11-2003, 09:18
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
While I can't really say anything for the staggered rollers, I assume it's so that pressure is held closer to the drive rollers so there is less chance of slack being a factor working against the drive roller. Some kind of a pre-tensioner?
As for the omni wheels, their productivity is two fold (possibly)
When the yellow block connected to the dark blue frame actuates vertically, the Tank-Treads would be lifted and the omni wheels in place.
If each omni wheel is idependantly powered, the bot would be able to have omnidirectional motion and have a smooth 0º turning radius.
If each Omniwheel set is powered by one motor, the bot would not have omnidirectional motion, but would have the smooth 0º turning radius.
According to the description, the tank drive is for slow & high torque applications, while the omniwheels geared for fast lower torque applications. Example: Omni's to get to the objective first, then the tanks for holding it.
Unread 07-11-2003, 13:45
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Originally posted by patrickrd
Hey M.
- Patrick
The most basic intent of this design is to provide a dual-speed drivetrain. This can, of course, be accomplished by a shifting transmission. But, it also allows for a team to use different wheel types or tread materials to best accomodate the playing field and the conditions the robot may operate in.
The high-speed configuration does have four omniwheels on the ground. This offers the advantage of a zero turning radius and it minimizes the force required to turn the robot -- allowing for maximum straight line speed. I also think it can powerslide through turns, which probably isn't useful, but still cool.
The omniwheel rollers aren't staggered for any particular reason. I've been exploring different ways of creating omniwheels that are easy to manufacture. What's shown is just one variation that's comprised of two 8-roller wheels offset and bolted together.
Of course, a team could replace as many of the omniwheels with regular wheels as they'd like.
The other large advantage here is that the wheelbase dimensions change when you shift speeds. The low-speed wheelbase is shorter than most other robot designs, meaning that the robot can exert more force while turning than a similarly geared drivetrain. Conversely, the high-speed wheelbase is larger than most other robots, making the robot more stable during direction changes at high speeds.
--Madison--
...down at the Ozdust!
pic: dual speed gearbox CD47-Bot Extra Discussion 9 07-10-2003 15:04
pic: Team 980 "Thunder Bot" drive train CD47-Bot Robot Showcase 12 25-02-2003 14:02
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
