Go to Post Dean: We encourage kids to learn about science, technology.... Colbert: And does that include creation science? Dean: .... Well we teach kids to be very creative..... - Kevin Sevcik [more]
Unread 07-11-2003, 16:59
MBosompra MBosompra is offline
MBosompra is an unknown quantity at this point
Shifting Gears
Hello all. I'll keep this short and sweet.
My team and I have decided that we are going to build a multi gear gearbox so that we can shift gears on the fly. We have 2 solid ideas on how too do it and were currently doing all the math. I would just like to here from others any difficulties you had with changing gears. Any words of advice or ideas would be greatly appreciated.
Unread 07-11-2003, 18:08
geo's Avatar
geo geo is offline
A Nuke Would Do The Job!
FRC #0865 (WARP 7)
geo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the roughgeo is a jewel in the rough
Keep it simple so when it do brake down it would be easier to fix.
2006 Greater Toronto Regional Winner!(with 1114 & 1503)
2002 Canadian Regional Winner!(with 610 & 781, our rookie year )
Unread 07-11-2003, 18:18
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Make it robust so it won't break down. (then it can be as complex as you want)
Unread 07-11-2003, 18:45
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Shifting on the fly is a challenge.
Bevel the teeth (grind them off at a 45 degree angle) of the mating gears. It makes the shifting smoother. Not all the way, mind you. Just on the edges.
We have tried programming a "synchro-mesh" system that would match the motor speeds. But up to now the computer power wasn't there. Maybe this year.
And you don't have to really shift on the fly. Think about what you are doing at the time you want to shift from high gear to low gear and low gear to high gear. You might be surprised what's really going on. I was.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 07-11-2003, 18:48
You don't have to mesh gears. You could have a shifter dog mechanism.
Unread 07-11-2003, 19:25
Gregory Frechou Gregory Frechou is offline
#1083 (Emoticons)
Gregory Frechou is an unknown quantity at this point
Send a message via AIM to Gregory Frechou
^could you elaborate
Unread 07-11-2003, 19:40
Bill Gold Bill Gold is offline
Retired -- 2006
Bill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond reputeBill Gold has a reputation beyond repute
Gregory Frechou:
http://www.chiefdelphi.com/forums/sh...ht=Technok at
Unread 09-11-2003, 00:50
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
I second the whole bevel-gears thing... we had lots of problems with the gears meshing until we did this.
Another thing I suggest goes to the programmers. When shifting, even our team's better drivers had problems getting the speed right. In the heat of the battle, it's hard NOT to be going in full throttle. As a result, when we were shifting, all of our drivers were putting too much speed in between gears, and the gears were making the clang-clang-clang noise of dhoom from sliding past each other and not meshing. What we did was we used two digital inputs and four limit switches (wired as shown in the 1-min Paint diagram below) to tell us when we were engaged and when we weren't engaged. At any point in time, the High-Gear OR the Low-Gear input must be 1. If both are 0, that means we're not engaged. When we're not engaged, the program limits the speed to something like 1/5th or 1/6th of the maximum speed - slow enough for the gears to finally mesh. This system is nice because its fully automatic - the driver can push as hard as he wants on the joysticks because the robot automatically limits the max speed.
Depending on how easily your system shifts, you might also consider having the program automatically go forward and backwards. We found that if you jiggle between forwards and backwards, it shifts faster. It's something you need to test out on your system and see how it works for you.
Hope all this made sense... it's 1am and I'm falling asleep, so my grammar probably isn't up to par. If you don't understand something, post and I'll get back to you in the morning.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 09-11-2003, 03:00
Mark Hamilton's Avatar
Mark Hamilton Mark Hamilton is offline
Belphegor made me do it.
#0108 (SigmaC@t)
Mark Hamilton will become famous soon enough
Send a message via ICQ to Mark Hamilton Send a message via AIM to Mark Hamilton
Perform all the math, figure out exactly how strong it needs to be, then build it 3x stronger.
Retired member of Team 108
Unread 10-11-2003, 12:26
Shifting Gears
http://jaw.iinet.net.au/crustyquinns/gears.html
I'd like to mention that this design is courtesy of the technokats.
Here are some ideas that we have. Please offer any and all words of advice it's greatly appreciated. We are rookies at building gear boxes. We're not sure which equations to use or even were to start. Please help.
Unread 10-11-2003, 12:28
Re: Shifting Gears
I would hate to have to make that. Although I would feel very proud after I did.
Unread 10-11-2003, 12:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Why shift gears when you can shift wheels?
--Madison--
...down at the Ozdust!
Unread 10-11-2003, 18:22
Rpifirst Rpifirst is offline
AKA: Nuz
#1493
Rpifirst is on a distinguished road
Send a message via AIM to Rpifirst
Yeah kickers. 190 did this very sucessfuly in 2001. But i think it takes up amuch more weight than a transmission.
Nuz
Lambda Chi Alpha
E.H.1103
Unread 10-11-2003, 19:02
Madison's Avatar
FRC #0488 (Xbot)
It is heavier, usually, but can offer more advantages as well. Not only does it allow you to change speed and output torque, but other things like wheel base, tread, width and type.
I've helped do it very successfully in 2002 and, with luck, I'm going to do it even better in 2004.
--Madison--
Unread 03-12-2003, 17:47
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Re: Shifting Gears
I just wanted to point out, that on the shaft we had bend, when we redesigned it to avoid the bending, we made it 8x stronger.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
