Go to Post Maybe you should whack it a few times with a hammer. That always seems to fix our robots. - Adam Y. [more]
Unread 10-11-2003, 20:42
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
In the user_functions.c there's a part that says "INSERT YOUR OWN CODE HERE" (or something to that effect). I'm assuming that's where you insert your own code
On the other question, I believe the Programming Guide says there's no way to switch between autonomous and user modes on the EDU-Controller. (I might be wrong on that one) But you COULD make some auto. code and then upload diff code to practice driving...
GitHub - Collaborate on code, documentation, etc. - http://github.com
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous sensor programming ? Laura_d Programming 1 10-02-2003 17:46
autonomous mode timer Don Programming 6 09-02-2003 22:16
How do you do the autonomous programming? Ryan Collings Programming 11 07-02-2003 19:38
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
