Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
Unread 19-11-2003, 02:18
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
We had this same debate.
Decision?
We decided to shift as early on in the gearbox as possible. (After all the motor combiner reductions and such). Basically, the reasoning behind this was, there is less torque applied to each shaft/gear at this end of the gearbox (higher speed = lesser torque). This means our shifter pins/dogs/whatever would be put under less load.
Problems with this?
We were worried that the high speed associated with this part of the box would cause our shifter to "grind" and not engage nicely. Some argued that perhaps at a slower speed, the dog/pin/whatever would engage "nicer".
Results?
She shifts beautifully from low to high, on the fly. She's not as fond of dropping from high to low while at full speed, but we're not worried about that as much.
She does make a nice little grinding noise as she jumps into gear, but, no damage or visible wear has occurred on our shifter dog, and the whole box seems to be functioning almost flawlessly.
*knock on wood*
Good luck to anyone attempting this. If you email me, or IM me, I'd be more than willing to share experiences, or help out with any drive design questions.
John
PS - The Technokitten Tranny shifts right after the motors combine (Andy has it shifting even earlier than mine does). They then go through another reduction afterward. In 2003, this additional reduction was mounted seperate from the main gearbox, and located on their tread assembly. The output from this secondary box turns their tread (direct drive). No chain.
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
What is it ESSENTIAL to do to a drill transmission... Iain Motors 12 04-02-2003 21:56
BOSCH Drill Transmission Assembly archiver 2001 2 23-06-2002 22:08
322 Three speed transmission. dkeith Robot Showcase 8 10-06-2002 22:33
Which teams are using a transmission this year Todd Derbyshire Scouting 10 08-04-2002 10:21
